my t5 installation
Discussion in 'Technical' started by Bryant, Jan 19, 2011.
  1. Bryant
    i have collected all the parts to start my t-5 swap. i will be doing the swap in my spare time and post updates with lots of juicy pics!!!! so here we go.
    this is the pedal assembly with the bracket i made.
    heres the assembly in the car.
    i made the bracket by hand. on the one we did for mo's swap we had a bracket waterjeted from a cardboard template we made. it was fustrating working with the water jet guy so i opted to make my own. its not very pretty but gets the job done.
    here it is.
    here are the dementions of the bracket if anybody wants to try to copy it.
    i have a friend who is good with a cad program and will have him make the drawings for it so i can have it waterjeted in the future and be able to sell it to members on this board.
    thats what i have done for now. ill take more pics and post them as i go.
  2. rayzorsharp
    Great Job! (y)
  3. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    X2
    Great work Bryant!
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Nice!!:thumbs2::thumbs2:
  5. mean_maverick
    nice setup.... only thing i'd do different is find a smaller clutch pedal (lower portion) to cut off and weld it on to make it look more original, but that's just me. kuddos for making ur own setup :thumbs2:
  6. Ryan
    Ryan Ford Addict
    Phoenix Az.
    All this fancy work and you cant drive to Autozone and get a new pad for your brake pedal? :rolleyes:
  7. Bryant
    i got a cnc pedal pad to weld on over the stock pedal pad so they will match when done.
  8. mean_maverick
    awesome. btw, where did u get your pedal assembly from?
  9. Bryant
    http://www.cncbrakes.com/
    im using a 7/8s bore master and 3/4 bore slave cylinder.
  10. mercgt73
    How did you choose the bore sizes? I was going to go with a 3/4" bore master and 7/8" bore slave, as seen in this article: http://midnightdsigns.com/Mustang/HYD Clutch.htm
  11. Bryant
    we first did this set up on mashori's car. we didnt get enough travel with 3/4 master and 7/8s slave and the effort to push the pedal was nothing. then we went with 3/4 master and 3/4 slave and still not enough travel and no effort. with the 7/8s we got plenty of travel and the effort is still very little but not too little. i belive that the pedal ratio gave us alot of leverage and not as much travel, and that is why this combo works.
  12. mercgt73
    Cool, good to know! Thanks!
  13. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    The clutch with the master that Bryant and I are using is really amazing and the way he has the mount setup work great in a stock car like mine that even has AC but I did have to get rid of the parking break. I'm sure we could have moved it pretty easily anyways.
    The best part of brynat's build is the bracket that the slave cylinder mounts on. They sell for $80-150 online. He's making his own. I wasn't there to witness this but my spy was able to get some pics . . .
    I don't think they are completed but it's pretty sweet how it's gonna turn out when he's done.
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    This is the one I have that was I think $200 and really not all that functional since it's hard to mount with the T5 on the car. I think bryant's design will improve on that.
  15. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    This is how bryant fabbed up the pedal bracket. We got some thick cold rolled steel sheet and used his blowtorch to cut the measurements out. Then used an electric grinding wheel to clean it up real nice.
