Drive shaft yoke comming up short
Discussion in 'Technical' started by Racer_X, Nov 1, 2011.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    Im using mustang frame mounts[V8] on my maverick and I had to slide the tranny and motor up as far as it would go to get the motor mounts to sit on them but now im afraid that the there may not be enough drive shaft yoke on the tail of the tranny. Now if I were to swap to maverick frame mounts[V8] would my engine and tranny slide back so that more of the yoke is in the tail shaft?:hmmm:
  2. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    Check and see if your frame mounts are on backwards. I did the same thing at first and the yoke wouldnt slide all the way in. Not sure if there is a difference in between the two someone else can answer that.
  3. Racer_X
    North Carolina
    there on right. checked all that b4 they went on
  4. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    Is it the same Engine, transmission and drive shaft as before?
  5. rthomas771
    What year Mustang? If you're using a '65 3-piece mount then there's a left mount and right motor mount.
  6. baddad457
    Try em reversed---left on right, right on left. And if you're running a 9" rear, there are long and short pinion yokes to compensate for length too.
  7. Racer_X
    North Carolina
  8. Racer_X
    North Carolina
    I tried them reverse when the motor was first put in and it didnt work reversed, i still have the factory 8inch rear that came in the car. do u know where i can get a longer yoke?
  9. Racer_X
    North Carolina
  10. rthomas771
    You need a longer driveshaft. Putting in longer yoke is not the answer
  11. Racer_X
    North Carolina
    thats why i wanted to know if u have to slide the engine forward if you use maverick frame mounts instead of the mustang ones like i have, dont have the money for a longer drive shaft lol.........
  12. shaneb
    shaneb Member
    Mckinney, Texas
    1973 ford maverick
    I did the v8 swap as well and went with the v8 frame mounts from autokrafters. Im sure someone here has some you could purchase instead of buying a new drive shaft.
  13. baddad457
    How do you know ? A longer pinion yoke just might be an easier solution to his problem, if his shaft length is just an inch or so too short.
  14. Racer_X
    North Carolina
    ........:thumbs2:.......
  15. 71gold
    ...how about the...correct frame mounts...:yup:
