Soi, i'm thinking of throwing my Maverick up on Ebay...
Discussion in 'General Maverick/Comet' started by Streamliner, Jun 9, 2013.
  1. Streamliner
    Streamliner Member
    My girl and i are in the process of buying a home in Florida and relocating from NY and the money from the car would help with moving expenses and other things....Problem is i have no idea what it's worth and no clue what to set the reserve at.....I know there's a limited market for it considering the way i built it.....I have a number in my head but i could be way off....I'd be curious what you guys would set the reserve at if it were you
  2. mercgt73
    If my first child was born as of today... I would even include a months worth of diapers.
  3. Mavman72
    Minimum of 25K for that beast...C'mon its basically a street legal road course racer.
    How could you ask less???
  4. mrskydog
    Muskegon MI
    Wow what a Awsome Car!! Very well done. I have no idea what you have in it, but to the right person, I would say a reserve of 25,000 dollars also. Its one of a kind.....sooooo Cool!!
    I need to grab a rag I am Drooling all over the place. :thumbs2:
  5. Streamliner
    Streamliner Member
    [FONT=&quot]1972 Ford Maverick Trans-Am Replica[/FONT]
    [FONT=&quot]I built this as a “what if” Shelby American were still churning out road race cars in 1972[/FONT]
    [FONT=&quot] Started with a rust free [/FONT][FONT=&quot]California[/FONT][FONT=&quot] car….[/FONT]
    [FONT=&quot]The goal was to make it as light as possible and make it street legal and although it hasn’t been raced or autocrossed, it is built to do so[/FONT]
    [FONT=&quot]289 CI…[/FONT]
    [FONT=&quot]Lopey cam…..Unknown specs[/FONT]
    [FONT=&quot]10:5-1 cr…[/FONT]
    [FONT=&quot]AFR 1402 aluminum heads….[/FONT]
    [FONT=&quot]1:6 roller rockers[/FONT]
    [FONT=&quot]Full length headers….[/FONT]
    [FONT=&quot]Edelbrock intake…[/FONT]
    [FONT=&quot]700 cfm Holley dp carb….[/FONT]
    [FONT=&quot]Remote oversized racing oil filter….[/FONT]
    [FONT=&quot]Fluidyne heavy duty oil coil with -12 an hoses…[/FONT]
    [FONT=&quot]Custom carbon fiber air box which picks up cold air from the base of the windshield[/FONT]
    [FONT=&quot]Aluminum radiator Custom made aluminum with 2 piece quick-connect shroud[/FONT]
    [FONT=&quot]HEI distributor[/FONT]
    [FONT=&quot]Completely welded in sub-frame connectors[/FONT]
    [FONT=&quot]Drive shaft loop[/FONT]
    [FONT=&quot]Custom made spring tower braces[/FONT]
    [FONT=&quot]Battery[/FONT][FONT=&quot] relocated to trunk[/FONT]
    [FONT=&quot]Custom made heim jointed adjustable struts[/FONT]
    [FONT=&quot]New upper and lower a-arms boxed for strength[/FONT]
    [FONT=&quot]Pro Shocks Adjustable[/FONT]
    [FONT=&quot]Upper a-arm mount points lowered 1” for improved geometry[/FONT]
    [FONT=&quot]1-1/16” Mustang sway bar adapted[/FONT]
    [FONT=&quot]1” removed from front coils[/FONT]
    [FONT=&quot]4 wheel disc brakes with cooling ducts[/FONT]
    [FONT=&quot]American Racing 2 piece Torque Thrust D wheels[/FONT]
    [FONT=&quot]265/50/15 tires on all 4 corners[/FONT]
    [FONT=&quot]T-5 transmission with Pro 5.0 shifter and custom made relocating handle[/FONT]
    [FONT=&quot]New clutch and flywheel with CNC reverse swing hydraulic pedal set up[/FONT]
    [FONT=&quot]6 pt. roll cage…Kirkey race seats[/FONT]
    [FONT=&quot]Autometer Gauges….Battery shut off switch[/FONT]
    [FONT=&quot]2”x 3” frame connectors…5 pt. Cam-loc racing harness[/FONT]
    [FONT=&quot]Plexiglass rear and quarter windows[/FONT]
    [FONT=&quot]Straight through 2 ½” {no mufflers} with X pipe[/FONT]
    [FONT=&quot]8” Ford rear with brand new Traction-Lok and 3:80 gears[/FONT]
    [FONT=&quot]Custom made [/FONT][FONT=&quot]Watts[/FONT][FONT=&quot] link
    [/FONT] [FONT=&quot]RCI fuel cell-19 Gallons[/FONT]
    [FONT=&quot]On-board fire system[/FONT]
    [FONT=&quot]Electric fuel pump[/FONT]
    [FONT=&quot]Cougar LED tail lights[/FONT]
    [FONT=&quot]Front fenders widened 1”[/FONT]
    [FONT=&quot]All side marker lights filled in[/FONT]
    [FONT=&quot]Grabber hood louvered and framework extensively drilled for lightening[/FONT]
    [FONT=&quot]Deck lid frame drilled for lightening[/FONT]
    [FONT=&quot]Louvered rear lower valance[/FONT]
    [FONT=&quot]This is a sole purpose race car that is streetable….[/FONT]
    [FONT=&quot]There is no insulating, sound deadening, heater, a/c, stereo or any thing else that doesn’t either make it go faster or stop better…..[/FONT]
  6. Craig Selvey
    I would say at least $20,000.
  7. 71gold
    way too much info. for an Ebay ad...
    "it hasn’t been raced or autocrossed"...not a plus...(no speed/times or handling info).
    $8500
    JMO
  8. maverickoutlaw
    maverickoutlaw Member
    St Marks, Fl
    1973 maverick
    $20,000 easy. Where in Florida are you moving to?
  9. rthomas771
    Maybe $12,500
    You mention frame connectors twice
  10. Streamliner
    Streamliner Member
    Palm Coast, near Daytona and St. Augustine
  11. Streamliner
    Streamliner Member
    I'm honest to a fault
  12. car-nut
    car-nut Glenn
    conn.
    I like it, the more detailed the ad the better. I would agree with others that around $20k would be a good place to set a reserve. I am sure you have more than that in there. Awesome car for sure, if I was in the market for that type of car I would find it very appealing.
    Good luck.
  13. scooper77515
    Not street legal in most states. I see no mufflers at all on this thing.
    I bet it sounds pretty nice, though!
  14. car-nut
    car-nut Glenn
    conn.
    What makes you think it doesn't have mufflers? I haven't seen any under carriage shots of the car posted?
  15. rthomas771
    Scooper can read :clap:
