2.3 conversion
Discussion in 'Technical' started by greengiant, Feb 17, 2019.
  1. greengiant
    greengiant Member
    N/A
    1973 Ford Maverick
    I have a 73 maverick with a 250 i6. I am looking into a 2.3 lima conversion. What engine mounts will I need and where is the best place to get them.
    McD1970 likes this.
  2. bmcdaniel
    If you don't mind me asking, why a 2.3?
  3. Krazy Comet
    Only factory 2.3 installs were of foreign origin, not marketed in US. AFAIK no US model used compatible chassis mounts, you'll be fabbing those. I believe someone was building one but lost interest.
    Chances I'd install A NA 2.3 are zero & none but mated with a T-5 stick, a turbo 2.3 from a Turbo Coupe is a fun engine. BUT that requires all the wiring and computer for EFI, as well as at least a 3.50 rear gear. I dunno if turbo will clear the passenger side spring tower.
  4. greengiant
    greengiant Member
    N/A
    1973 Ford Maverick
    There was a 2.3 turbo maverick on youtube. It is now a 460 car. My reasoning is simple. I have access to a lot of performance 2.3 stuff. My dad has ran 2.3s in rangers for years and has acquired lots of performance stuff. He has one with a draw through carb turbo that has gone 7s in a ranger pulling the wheels knee high that I might be able to get. The turbo setup should fit, given that it isn't wider than a 302. Its gonna be a track car so probably gonna run 3.73s (thats the gears dad likes to run in the rangers).May see some street time but mostly track.got my eye on a c4 bellhousing for a 2.3 as well.
    mvw66gt likes this.
  5. greengiant
    greengiant Member
    N/A
    1973 Ford Maverick
    Basically I could be different and beat GT Mustangs in a 4 cylinder car, which is always fun (y)
    rwbrooks50 likes this.
  6. Hotrock
    Munroe Falls, Ohio
    A 2.3L would be an interesting swap.
    You may however, wish to read through the thread at the end of the following link:
    http://mmb.maverick.to/threads/1976-maverick-2-3-swap.85195/
  7. greengiant
    greengiant Member
    N/A
    1973 Ford Maverick
    Thanks for the link. Most of his issues I won't I have. I don't plan on running A/C or Powersteering. I will probably run an early ranger alternator bracket which puts the alternator up high. As far as the turbo I can pick up a high mount header for around 150 bucks. I am planning to rebuild the factory c4 and just add the 2.3 bellhousing and converter, plus I want a floor ratchet shifter so shift linkage wont be a big deal. The hardest part for me it looks like will be the engine mounts and wiring which isnt a big deal because I will likely run a simple early ranger style fuel injection which has very little wireing to it.
    mojo likes this.
  8. McD1970
    McD1970 New Member
    Nc
    1970 Ford Maverick 6cyl 1973 Maverick Grabber 302 w/351w heads 1967 Mercury caliente 289 4v currently building 428 3x2bbl 4spd for it
    I've seen this done. It's a cool and different swap. I'd be interested in updates on the build. Good luck
  9. greengiant
    greengiant Member
    N/A
    1973 Ford Maverick
    I got the bellhousing for the C4 and I may have an engine. My dad told me I could have his old spare turbo engine for the build if it's still useable.
    Hotrock likes this.
  10. greengiant
    greengiant Member
    N/A
    1973 Ford Maverick
    Well. Turns out the bellhousing I got is wrong. If anyone knows where to find the right bellhousing to put a c4 behind a ford 2.3 it would be helpful
  11. Krazy Comet
    Well good luck, 30-35 years ago you'd trip over the things at any salvage yard. Nowadays they seem all but extinct.
  12. bmcdaniel
  13. yellow75
    Tillamook Oregon
    You would have to want it pretty bad to pay that price
    mojo likes this.
  14. Hondatechcr
    Hondatechcr Member
    Myrtle beach
    1972 maverick 4 door
    I am actually debating doing this swap also, I currently have a 91 ranger 2.3 turbo swap and just picked up a 72 maverick 4 door and I keep thinking that engine would look great in there.
    I currently run a c4 trans, you need a very specific bell housing certain ones have smaller dowel pin holes and require custom dowels. Look on FB turboFord there are guys selling them on there. I paid 250 for just my bell housing and it was worth every penny.
    Good luck I'll be following your build, I hope you go through with it.
