Front Valance Redo
Discussion in 'General Maverick/Comet' started by 55crownvic, Sep 12, 2015.
  1. 55crownvic
    55crownvic Member
    colorado springs
    groberts101, biggruss and Paul Masson like this.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
  3. mav1970
    Looking good :thumbs2:
  4. 71gold
  5. Paul Masson
    1971 Grabber
    Nice subtle modification. Hopefully it doesn't restrict air flow to the radiator too much.
  6. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I like it :yup:
  7. yellow75
    Tillamook Oregon
    Looks killer, have you ever thought about changing your grill out to an earlier grill
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Grill should be the same as any Grabber grill. He has later model parking lamps and that plastic divider is removable if I recall correctly.
  9. yellow75
    Tillamook Oregon
    You are correct I guess I should have said the grill lights and remove the divider bar, it just looks different being a small bumper car with those lights. Yes I know it is a 76 converted to small bumpers.
    Either way the car looks great and have followed the build on it and wish mine was that nice
  10. groberts101
    groberts101 Member
    Minneapolis, MN
    Very nice. So well done it even looks factory and is exactly what I want to eventually do to mine too. Not sure if I will integrate the custom spoiler into the valance or keep them separate though.
    Paul mentioned potential for airflow reduction over the rad core. My feeling is that there's already TOO much air flow into the engine bays of these cars. Especially at higher/very high speeds as it accumulates and starts to lift the front tires. Granted, much of that effect comes from too much air under the front valance but overly large grill and factory valance openings surely don't help the situation one little bit. I plan to mitigate some of this issue by doing similar and closing off a fair bit of my valance opening and also using various vent locations(an ancient Chinese secret right now and you guys ain't Chinese) to exhaust the engine bay prior to too much airflow getting under the cars chassis. Plus, proper rad shrouding still allows draw across all cores at lower speeds because the flow doesn't necessarily have to be directed and pulled linearly through the front openings at low road speeds. E-fans can help this situation even more. Newer cars very small grill and valance openings are a testament to that. Plenty of gaps everywhere on the front end of these old cars which amounts to HUGE air volumes coming in from every nook and cranny. Then we need to add all that extra volume coming in from under the valance into the equation anyways. Just my quick thoughts on that subject.
  11. 55crownvic
    55crownvic Member
    colorado springs
    The car is actually a 69 1/2, I like the later grilles and parklights better than the earlier ones, so I changed the grill, that left a huge opening for the old lights below the bumper and when I found Mavaholics thread, I new that is what I wanted to do to mine.
  12. Mavaholic
    Looks great!!! I stole the idea from Mark Gustavson.
  13. rthomas771
    Todays Lesson...:slap:
    grill
    : to cook (food) on a metal frame over fire
    : to fry or toast (something, such as a sandwich) on a hot surface
    : to cook (food) directly over or under high heat
    Full Definition of GRILL
    transitive verb
    : to broil on a grill; also : to fry or toast on a griddle
    a : to torment as if by broiling
    b : to question intensely <the police grilled the suspect>
    grill·er noun
    grille
    noun \ˈgril\
    : a metal frame with bars running across it that is used to cover or protect something
    Full Definition of GRILLE
    : a grating forming a barrier or screen; especially : an ornamental one at the front end of an automobile
    : an opening covered with a grille
    usually grill : a set of metallic covers for the teeth
    71gold, Shorty and Paul Masson like this.
  14. Maverocket
    Northwest
    The extra "e" is to much work, just like the extra "o" in too!
  15. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I appreciate stuff like this.
