ground engine to frame
Discussion in 'Technical' started by shayne95, Jul 30, 2015.
  1. shayne95
    shayne95 Member
    Pt Richey, Fl.
    71 maverick grabber
    can anyone tell me where the strap or wire that grounds a 302 block to the frame is located
  2. Hotrock
    Munroe Falls, Ohio
    I've been told the Maverick/Comet did not come from the factory with an engine ground strap. I have a ground strap on the passenger side from a bell housing bolt to the firewall.
  3. mercgt73
    mercgt73 Member
  4. 71gold
    I have a ground strap from each head to firewall...
    one from starter mounting bolt to frame and one from batt.( in trunk ) to frame.
    mercgt73 likes this.
  5. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I have to admit that my first thought when reading the thread title was "How in the heck do you GRIND and engine down to the frame?!?" :slap:
  6. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    On mine the neg cable goes from battery to the lower bolt on the block, and where the cable passes the voltage regulator there is a clamp soldered that goes under the bolt for the VR on the apron
  7. 71gold
    that's good for a stock system. you will need more ground if you run more electronics...:yup:
  8. Grabber-1
    Grabber-1 Member
    long island ny
    71 maverick
    I don't know..., I guess I should clarify .I'm running 100 amp alt~ aftermarket stereo, rear defroster, DRL with upgraded headlights, electric fan and fuel pump. It's a 2gauge from battery to block and 4gauge block to apron. I opened the stock clamp at the the VR and soldered the new I pretty much followed what was on my 300M. Actually the positive and negative cables are 300M pieces. Sorry for the confusion I should have explained myself better to begin with.
  9. 71gold
  10. bomrat
    bomrat Member
    North Little Rock, AR
    74 Comet 4dr 347 4r70w
    i grounded mine at the lower front right of the 302, nice easy bolt location to the battery
    then i have a second strap from the body to the battery.
  11. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    I have my battery in the trunk so I went a little overboard. I ran a negative ground wire from the trunk up to the firewall and from the fire wall to a common ground location on the frame rail. I then grounded the motor in 4 places. Starter to a frame bolt for my steering rack bracket on the passenger side, random block bolt hole to common accessory ground on the frame rail where the battery used to be, drivers side random block bolt hole to frame rail on drivers side, and then one more from the rear of the intake manifold to the firewall.
  12. 71gold
    no ground strap from heads...:huh:
  13. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    heads are grounded to the block via the head studs and block is grounded to frame. Heads are grounded to the intake and intake is grounded to the firewall.
    Krazy Comet likes this.
  14. Rasit
    Rasit Member
    SE Pennsylvania
    Like "head bone connected to the neck bone, neck bone connected to the back bone......." :whistle:
  15. 71gold
    so were both of these heads...:yup:
    "Electrolysyisisysi damaged both my AFR (aluminum) heads."
