Maverick T5 clutch cable
Discussion in 'Transmissions' started by BossMaverick87, Oct 14, 2009.
  1. BossMaverick87
    BossMaverick87 Member
    California
    Maverick with cougar taillights
    Earl, where did you position your firewall brace? The best location I see is between the master cylinder and the fuse box. Did you mount yours there? the brace I got from the kit is a snug fit and it doesn't, look like it'll be 100% straight with the quadrant for the cable
  2. Earl Branham
    Lugoff, SC
    My brace is right beside the master cylinder, and just below the lip on the cowl/firewall seam. Go here:
    http://mmb.maverick.to/showthread.php?t=55831
    You will see my pics of the install. Any questions, pls let me know. Good luck!
  3. BossMaverick87
    California
    I can see that our master cylinders are slightly different. My firewall brace seems to be having clearance issues with my clutch pedal bracket's top right bolt. I most likely will need to modify one or the other to get the brace to fit. Which do you suggest? the bolt, down to just having the nut hold it down, or the brace?
  4. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    there is also a blow proof bell-housing that can be used with the cable or the mechanical OEM linkage for the t5 transmition....dependant on what pressure plate you use, you will have a smooth clutch, a mechanical shifting linkage will most likely be a little stiff ...FWIW I have a f350 crewcab dually with a six speed and hydralic system and a trooper five speed with a clutch cable and there is no feedback or feel to whats is going on, but on my 4speed fairlane with the mechanical linkage feels so good !!!! and the hurst competition plus is light years ahead of the OEM shifter !!!! love hitting those gears !!!!!
  5. ElMachine
    ElMachine Member
    Parts Unknown, Alberta
    1976 Mercury Comet
    Are you guys using the 65-66 kit or the 67-68 kit?
  6. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    I used the 65-66 kit.
  7. ElMachine
    ElMachine Member
    1976 Mercury Comet
    I figured that one would be the more universal fit
  8. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    This seems alot harder than how i did mine.A little fab work and presto.Larry Winter's turned out a little neater because mine was the "test pattern"
  9. mean_maverick
    same here. mine was a breeze with very little fabbing... :huh:
  10. ElMachine
    ElMachine Member
    1976 Mercury Comet
    Just use a stock Mustang cable?
  11. greengt429
    greengt429 Member
    Lordstown, OHIO
    70 Maverick Grabber, 69 mach1 351w 4spd, 71TorinoGT 429CJ 4spd sold last year, 90 LX 5.0 5 spd., 2014 Roush Mustang
  12. Acornridgeman
    Wisconsin
    I used a hydraulic clutch set up from Modern Driveline ........... totally satisfied with it. Takes a bit of skill to get it in but once completed everything is just right with how it feels and works. It's not cheap once you buy the master unit and a slave - but it is the only way I would set up a car again if I had to.
    66-70 Fairlane Hydraulic Clutch Master Kit - Modern Driveline
    dyent likes this.
  13. fredee
    fredee Member
    South MS.
    1971 comet
    Agreed my son just put a TKX in his maverick with this setup. Had to add another washer to the pivot stud .200 total thickness. But now its perfect.
