moving on...rear shocks
Discussion in 'Technical' started by 71gold, Nov 6, 2017.
  1. 71gold
    what are you Guys and Girls using for a street rear shock?
  2. mojo
    KYB "Gas" Blacks! Had them about 4-5 yrs, satisfied w/ them. I have them w/ the General Springs and bottom leaf removed " by suggestion frm you".
    71gold likes this.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Koni
    Micah
  4. junrai
    junrai Member
    rancho cordova ca
    I want to say mine are kyb gas as well but with my leaf springs and traction control kit my car rides like a truck WITHOUT shocks lol
  5. 71gold
    Micah and Mojo do you have a part #...:Handshake:
  6. tody
    tody Member
    cologne, germany
    71gold likes this.
  7. mojo
    Part # for KYB --- Excel-G 343136 rear, 343146 front. I have on my car and work great for me. I do think I had to use upper hardware bolt on pass side rear from existing shock for some reason, or would have to made some kind of mod. Don't recall exactly why "been abt 5 yrs" -- took easy way out.
    71gold likes this.
  8. 71Mavrk
    71Mavrk Member
    Nevada
    DSC_5047.JPG I picked mine up as NOS from eBay. Without crawling under the car, I don't know the numbers. Even then, I repainted them to match the car and might not see any stamped numbers.
    When I look at Rock Auto, they list KYB KG4517 for the Maverick. It also fits the 64-70 Mustang. If you look up a 70 Mustang at Koni, it comes up with 8250-1031.
    Micah
    71gold likes this.
  9. dyent
    dyent Member
    vancouver bc
    Frank:
    I believe the 64-70 Mustang rear Koni's will not work, has threaded studs at each end, our Mav/Comet only use the threaded stud on bottom and eyelet for top mount. I have the Koni Special 'D' adjustable p/n: 80-2235 it has 5 adjustment settings from soft to firm, where you literally need 2 people to extend/compress, great for damping super high rate rear leaf springs (mine are 5 1/2 leafs). Unfortunately, these are long out of production, nice thing Koni's are rebuildable if they where ever to fail.........
    David
    71gold likes this.
  10. 71gold
    73' maverick...
    anyone know the correct orientation of the top rear shock mounts?
    I had mine off when I cleaned and painted the undercarriage and don't know if at that time I replaced them correctly.
  11. 71Mavrk
    71Mavrk Member
    Nevada
    David,
    I 'm certain the Konis I installed were for a '70. I just had to do some maneuvering to get them into the upper mount but otherwise they worked fine.
    Micah
  12. yellow75
    Tillamook Oregon
    I had QA1 nine way adjustable on my car but you have to put a piece on the bottom to change the orientation of bottom shock mount from a post to a bolt that goes through it like the top mount.
    https://www.aa-mfg.com/bolt-on-coil-over-mount
  13. 71gold
    I got the shocks back on. really only one way the top mount will work on each side. the mounts are the same L/R . driver side, mounting tab to front of car...the pass. side to rear of car.
