My 71 Maverick Grabber Build.....
Discussion in 'Maverick/Comet Projects' started by franktf, Jun 6, 2010.
  1. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Went down this morning and worked on filling unneeded holes in the firewall and driverside rear apron area.....
    Here's the firewall and driverside rear apron before filling the holes.....
    Here's the firewall and driverside rear apron after filling the holes and cleaning the area up.....
  2. Dave B
    Where's the throttle cable going to go? I'm planning on filling a few holes,, once my knee gets better, and I can work on my car again...
  3. Recrdholdr
    Recrdholdr National Record Holder
    London Ontario
    I want a 70-73 Maverick
    Maybe he's going to put in an LS motor with a fly by wire throttle. LOL
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I just knew someone was going to ask that question, I am going to use a Lokar cable so I just need to drill a 5/16" hole now that the old ones are gone.....
    Not gonna happen atleast with fool injection, it would have to be carbed if I did it..... :p
  5. Dave B
    I wondered....I'm using the Lokar cable. I just knocked the fitting off a factory cable.
  6. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I picked up the material for the reinforcement sleeves, shock tower plate and pieces to make my motor mount towers.....
    I was at the shop for a while this evening waiting for someone to drop a carb off I bought..... While I was waiting I did a little work on the car, I cut the reinforcement sleeves for the k-member bolt - got one cleaned up, welded in and ground smooth.....
    Here's the first sleeve welded in and the other 3 cut off ready to be cleaned up.....
    Here's the carb I bought, it's an old Barry Grant 675 Silver Claw(it's a dirty but seems to be in real good shape)..... It's probably a little small for the combo, but will make a good starter carb for it and for $125 I just couldn't beat the deal..... I will probably tear it apart tomorrow to see what it looks like inside.....
  7. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Went to the shop this morning and took the carb apart too see what it looked like..... Aside from being dirty it is in excellent shape and as a bonus it has completely adjustable air bleeds, idle feed restrictors and emoulsion circuits.....
    After that I welded the reinforcent sleeves in the front frame for the k-member mounting holes..... Then I filled the unneccessary holes in and made a rust repair on the pass side rear fender apron..... Last thing I did was clean up the upper insides of the quater panels and roof rails where they were bare metal from the factory and surface rusted, then coated them with POR15.....
    Here's the sleeves being installed..... First pic is the sleeve in place with a rod sticking out of it for squaring and alignment purposes, the second is with it welded to the bottom of the frame and the last is with the weld ground smooth.....
    Here is the rear fender apron before and after repairs.....
    and this is the upper inner quaters, roof rails and under side of cowl coated with POR15.....
  8. tody
    tody Member
    cologne, germany
    must be really nice to work on the car upside down!
  9. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    It allows you to work on things that would be nearly impossible otherwise.....:D
  10. tody
    tody Member
    cologne, germany
    unfortunately, my next project is an econoline van - i doubt you can put that one on a rotisserie :cool:
  11. maverickfever
    maverickfever maverickfever
    Winnsboro SC
    26 Mavs and Comets
    I hope when i tear my grey down,it is that good.You got a real gem there,congrats.
  12. mav1970
    Just need a really high pivot point :D
  13. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    Thanks for sharing all these pictures with us Frank. Great work!
    Do you have any tips on "must have" tools from places like Eastwood, when getting our cars down to bare metal??? Like a short list that includes sandpaper block types, wirebrush types, special tools etc. I know most of it is elbow grease.
  14. mav1970
    I've used these 3M velcro backed paint remover pads to strip every inch of paint from my car if you want to give it a try. It might cost you 20 bucks the first time but you're buying an arbor and a disc together. Then each single disc costs around 10 bucks. You can see pictures of it in the thread below
    http://mmb.maverick.to/showthread.php?t=69388
  15. cactusgrabber
    Tempe, Arizona
    72 Grabber
    Thank you Bob! I will check those out.
    And Frank and others can throw your favorite tool tips in the ring also. I will use your guy's tips when I get to that point with my Grabber.
