One 4" long 10 gage wire.....
Discussion in 'Drag Racing' started by Rick Book, Aug 5, 2006.
  1. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    I've never had a full pass at a track.
    The first and only times it ran down the track was at Windy Hollow Dragway at the Roundup.
    It was running like carp - my best 60' was an embarassing 1.8X (and that was with Frank pushing me! ;) ). I would load up the converter and the engine would fall on it's face @ WOT. Just not enough spark.
    I'll keep everyone posted of how it runs next time out - hopefully MUCH better!
  2. Rick Book
    Rick Book Member
    Thailand
    Gotta love it! That's exactly the goal I want to attain one day.
  3. okibono
    okibono Member
    cali
    LOL, VatoZone...
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    My 1-wire required a jumper (fortunely the previous owner) Mr. Moore had me covered. I have since had the alternator rebuilt, went up to 110 amp and a "true" 1-wire. Not had any problems (its a chevy :rolleyes: )...I sure do not miss the days of cranking the ole gen. and hooking up the charger between rounds.
  5. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    thats the best thing to do...until the aggrevation has passed, then get in there and get it fixed!
  6. 71gold
    seems to me there were a lot of (trailered) car problems :huh: .
    did anyone else :drive: their (one wire alt.) home and park it in the garage besides me :huh: (y) ...frank...:bouncy:
  7. scooper77515
    Hey, I have the same Chevy 1-wire, with the jumper, but it only charges at 12-12.5...it should be 14, shouldn't it? Did I do something wrong? They tested it at the shop and said it was just fine.
    Might it be because I have it running all the way back to the trunk to charge the battery?
  8. Rick Book
    Rick Book Member
    Thailand
    Scott, you might be checking it at idle. I'd see if it registers the same at higher rpms. If so, you might consider a smaller diameter pulley to turn the alt faster at idle rpm.
    I'm getting good numbers at idle with an UNDERDRIVE pulley. :confused:
    f.y.i. I've attached a picture of the Infamous Jumper.
  9. scooper77515
    What do you think...?
    I bought the jumper with a red and white wire already attached to a plug that fits on the two flat blades (only fits one way with a little notch). The white I have attached to the ALT light at the dash, and the red is the jumper.
    It appears that you are jumping to the other blade??? :huh: Am I seeing that right (mine is shot from under the car)? It looks like you are jumping from the post to the closest blade.
    Also, appears to have a larger wire...wonder if THAT is my problem?
    Runs a consistent 12-12.5 at all rpms. I AM running an electric fan and fuel pump, but those shouldn't affect the charging.
  10. bmcdaniel
    Instead of a jumper you should probably run a sense wire back to the battery. That way the regulator "knows" to supply full voltage to the battery.
  11. scooper77515
    So, extend the red "jumper" all the way back and not to the post? Seems like it wouldn't know the difference where it is connected... :huh:
  12. scooper77515
  13. bmcdaniel
    That's the purpose of the remote wire, to let the regulator read what the voltage is "back there". Right now it's reading optimum voltage at the alternator terminal and thinks everything is fine. Your long battery cable/connections are probably dropping some voltage but the regulator isn't being informed.
  14. Rick Book
    Rick Book Member
    Thailand
    Scott,
    Yes, we are using different terminals to jump to the "main" terminal (for lack of better word).
    I just took a gamble and hooked up a jumper wire to that one terminal and the alternator started putting out 13V+ on the tester. I really had no idea which post should be jumpered - or if even one was supposed to be jumpered (is 'jumpered' a word??).
    Because the first terminal I tried worked, I didn't try the other post for fear of burning up the alternator.
    Unless someone informs me that the terminal I'm using is the wrong one, I intend to keep using the same terminal I have the jumper hooked up to now.
    p.s. no prob on what you think might be 'hi-jacking' this thread. I believe your info to be very relevant. You can delete the other post to keep everything in one thread if you want.
  15. 71gold
    scoop,
    how long you been running this alt.? i had to run an "exciter" wire to turn the alt. on. without it you will just be reading the volts that are in the batt.:yup: mine want hook to the alt. light. i have a digital volt gauge.
    ...frank...:bouncy:
