Roger's Idiot thread for a 302/C4 into a '70
Discussion in 'General Maverick/Comet' started by smegnl, Sep 18, 2019.
  1. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I put it on a watch last night just to see what it sold for and recieved an offer to buy it for a discounted price. I already have the stuff so I won't bid but thought you'd be interested in knowing the seller will deal.
    BBMS18 likes this.
  2. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    ill reach out to them.
    EDIT: He did come down a little. I bought them. Thanks again for the heads up. Saved quite a bit over new.
    RMiller and BBMS18 like this.
  3. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
  4. Craig Selvey
    You will need to change out the pedal to a later style.
  5. yellow75
    Tillamook Oregon
    You got the later style pedal with your purchase so you are good to go . I hate when people wont take a few minutes to clean parts up that they want good money for but he moves a lot of volume and has no problems selling it just not my style
    William623 and RMiller like this.
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    thanks on the pedal information. Not only did he not clean them, but used dirt as the background :huh:
  7. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    You’re not giving yourself enough credit, most people would screw things up then come here for help.
    You had enough common sense to ask questions before making a mess of things, this tells me with help from the members here you will get your car fixed up & then be able to cruise it with pride knowing you did it yourself.:1st:
    Russell, CA189HJN, stumanchu and 2 others like this.
  8. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thanks. I really appreciate that.
    BBMS18 and Wilbur Green like this.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    OK, i got the 302/C4 today...
    The guy helping me said he was glad it was a "truck c4" . Something about the bell curve on the C4 being bigger/longer.
    Here it is. Am I going to have an issue getting that in the skinny '70 tunnel?
  10. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    I don't know what he was referring too, but I don't think it'll be an issue for you. The C4 used multiple bellhousings depending on flex plate tooth count, torque converter size, and other variants, including one for the 351M/400. Here's some good information about the C4: http://www.mustangcentral.net/tech/c4.html
    More here: https://www.advanceadapters.com/tech-vault/1-ford-c4/
  11. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    The "truck" version is just a pan fill versus case fill. Internally I've read that they are the same. Lots of information out there on the Internets. I have a pan fill on my '75 and fits fine so there shouldn't be much of a clearance issue.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Ok sounds like the thing I need to find out is will a PAN filled C4 case fit in a 1970. Thanks, that will be easier to research.
  13. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    It should. All the internals are the same, the dipstick tube is just located differently.
  14. Krazy Comet
    The pan fill, truck C4 has a slightly larger 164T bell housing than does the case fill that used a 157T. The cases are all same size.
  15. stumanchu
    stumanchu Stuart
    Portland, OR
    Dont want overthink anything, but will a v8 radiator hose clamp down to the smaller I6 radiator? I never tried and dont know. BTW, Go Roger!!!!! I wanna see the IT guy pull it off!
