Steering column collar interchange for 1971?
Discussion in 'General Maverick/Comet' started by xpsnake, Mar 27, 2015.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I did a bunch of searching and didn't see anything useful yet. Has anyone had experience with swapping a floor shift column collar from another Ford onto a 1971 Maverick automatic column shift column? I finally pickup a manual transmission and would like to update my column when I make the swap. I know plenty of folks have just removed the column shifter and filled the holes but I'd love to swap parts if I can.
  2. Krazy Comet
    Dismal Swamp
    Well I dunno, but suspect are different as because of locking rod for transmission...
    For the record that plain collar Pt # is D0AZ-3790-A, used on '70/'71 Full Size, Torino, Mustang and Mav with floor shift... Probably on others as well...
  3. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    My son just did that very thing on his 64 Falcon using a 64-66 mustang collar .
    He removed all the shift tube and levers reused the turn signal plate and the outer tube .
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
  5. rthomas771
    Things I notices when swapping the end of the column doing a column-shift automatic-to-t5 swap on my 74 using 71 parts.
    The early collar has a smaller channel for the key switch to slid into, along with a smaller release pin and this caused my lock not fitting the early collar. Also the slot for the emergency flasher switch is not cut deep enough for my turn signal switch to fit all the way in the collar. The turn signal switches are interchangeable...different harness plug. Since I didn't have a key to fit the '71 column I decided to fill the gear indicator slots on my automatic collar with JB Weld. The other piece of the collar for the shift lever swapped out with no problem.
    [​IMG] [​IMG]
    xpsnake likes this.
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    This is premature and does not answer your question, but I took the two collars from a 71 - 73 Mustang, and although I have not yet attempted to switch them they do appear identical. So it is probably as Krazy Comet Tom says.
  7. xpsnake
    xpsnake Bruce
    Thanks guys. Gives me some ideas for the fall.
  8. xpsnake
    xpsnake Bruce
    Keep us updated in this too!
  9. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    True. I used a collar from a 72 Mustang on my 70 when I switched to floor shift. Worked great.
  10. bartikus
    bartikus Member
    salt lake city, ut
    i pulled the standard trans collar out of a 1984 ford f150. i don't know if it is going to work but i will find out.
  11. rthomas771
    I got a 76 Mustang II collar in my pile of parts. It looks like it will work but it has the silly lever to flip to get the key out
  12. Collin Hale
    Collin Hale Member
    Does anyone who did this have an extra shift lever they could sell??
  13. xpsnake
    xpsnake Bruce
    If you post in the want ads, I'm sure it won't take a few hours before you'll have one to buy.
  14. Collin Hale
    Collin Hale Member
  15. xpsnake
    xpsnake Bruce
    Did any of you guys besides Jeff ever actually try your parts?
