VIN Sequence number... how close is your car to someone else's???
VIN Sequence number... how close is your VIN to someone else's?
  1. BBMS18
    BBMS18 Member
    Grand Rapids, Michigan
    75 Comet
    If your door tag says made in Canada that would match the X plant in vin, and in my opinion confirms a typo on title.
    First digit is the model year. 0 is 1970, 1 is 71, 2, is 72, and so on up to 77.
    Second digit is the plant it was built at:
    K = Kansas City
    X = St. Thomas, Ontario, Canada
    W = Wayne, Michigan
    F = Dearborn, Michigan
    Third and fourth are the body codes:
    91 = standard 2 door Maverick
    92 = 4 door Maverick
    93 = Grabber
    30 = 4 door Comet
    31 = 2 door Comet
    Fourth number is the engine code:
    U = 170 I6
    T = 200 I6
    L = 250 I6
    F = 302 V8
    The last 6 digits is the number the car was assigned when it was scheduled for production. For example 167193 would be the 67,193rd car scheduled for production by the factory for that model year. 216890 would be the 116,890th car.
  2. Fuelsmoke1
    Fuelsmoke1 Member
    Belton sc
    1975 ford maverick sedan
    Thank you. I should have taken picture of my tag . On line, below the axle codes and color codes it says Made in Canada. I will get a picture tomorrow.
  3. Fuelsmoke1
    Fuelsmoke1 Member
    Belton sc
    I'm thinking about getting a Marti report , I'm going to call them to see if they can run both vin numbers. Pretty certain this stemmed from an error at some point either reading it wrong or just a typo at dmv. Marti should be able to prove that the wrong vin doesn't actually exist. And the Canada label should support the X in the vin.
    BBMS18 likes this.
  4. Krazy Comet
    Made in Canada, 5X would be good enough for me.
    Should have same VIN on windshield tag (it's the one that actually counts)as door. VIN screw ups are a fairly regular occurrence.
    Just as likely he can prove it does, or at least did exist. VINs start 100001 at each plant, only digit that is always different is assembly plant.
  5. Craig Selvey
    As stated in a round-about way.....YES two cars could have the same last 6 digits of a VIN. They could both be Mavericks made at different assembly plants, but could also be two totally different cars/trucks.
    CaptainComet likes this.
  6. Krazy Comet
    When I was keeping the 428 Fairlane registry, I had over 500 428 Fairlanes & Torinos, never found one with same six digits(no doubt it happened). Those were all Q or R code engines so that part was fairly constant. I did have two or three pairs of consecutive VIN from same plant.
    Craig Selvey likes this.
  7. Birkan
    Birkan Member
    Thousand Oaks, CA
    1973 Maverick LDO 302
    73 Maverick vin # 3K91F163132
    302V8
    Production schedule date 1/1/1973
    Date delivered to owner Jan 23 1973 at Bob Wondries Ford in Alhambra, CA
    Paul Masson likes this.
  8. CaptainComet
    I am agreeing with Craig here. If you have two identical VINs except for assembly plants the two vehicles would likely entirely different models.
    My Comet was made in Kansas City. The last batch of six numbers after the engine code starts with a 5 meaning it is Mercury (Fords start at zero), but that takes in all Mercury cars made there at the time, several models.
    Going by the VIN in question there, they made a quarter million Ford cars at that plant that year!
  9. Krazy Comet
    I'm not sure what models beside Maverick/Comet were built at Kansas City(no doubt last of '69 & early '70 Falcons, were also built at Oakville). Till the early March '69 switch over, KC was also building Fairlane, Torino & Ranchero, but no Mercury intermediates. All those came from Lorain that also built all the Torino/Fairlane convertibles. Till the switch, Ford had four plants building Fairlane/Torino.
    Poking back through my regestry records, I have a '69 Cobra from Atlanta & Torino GT from Lorain that missed same consecutive six by one digit, xxx196 & 197. Of course body codes are different(46 Cobra, 42 Torino GT) so in actuality three digits are different. If 196 at Lorain was a Cobra then all the stars would be in alignment. I have several cases of same consecutive from different plants missing by less than 10.
  10. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
  11. maverick306
    maverick306 Member
    Kinston NC 28501
    1974 ford maverick
    This is my vin #4W93F236737 1974 Grabber
  12. Paul Masson
    1971 Grabber
    Added to the 1974 VIN List HERE. Thanks for sharing!
  13. Paul Masson
    1971 Grabber
    Added to the 1973 VIN List HERE. Thanks for sharing!
  14. Paul Masson
    1971 Grabber
    I haven't posted in a while. I think this gets us caught up on the VIN Lists. Thanks everyone for sharing your VINs!
  15. gator25
    gator25 aka No No my name is Nolan
    NW Louisiana
    72 maverick, 77 K20, 75 K5, 75 K20, 82 C30, 85 C30, 78 Monza Scorpio and a lot more junk.
    2x91t114391
