  1. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Put my Comet GT to bed for the winter and took stock of my parts collection and what I still need to start working on it in the spring. - Matt
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    MERRY CHRISTMAS & HAPPY NEW YEAR Y'ALL !!
    Cometized
  3. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
  4. maverick600
    maverick600 Member
    San Angelo, Texas
    I replaced my rear shocks and gave her a bath. She looks much better now.
  5. leeinphx
    leeinphx Member
    Show Low Arizona
    1975 LDO
    This weekend, started wiring up the 5.0 EFI with the painless harness, put the long tube headers on and started mocking up the exhaust, then decided to go ahead and pull the C4 and put in the AOD from the donor car before I tightened down the headers. Everything was going fine until I got to looking at the shift linkage. The drivers side long tube headers come in very close to the shift linkage and would melt the rubber covering. The AOD from the Cougar donor floor shifter has a cable system, but is reversed from a hard linkage system that is stock on the factory floor shift (shift lever points down on the donor). The TV cable lever won't allow the shift linkage to be swapped to the upright position. Looks like shorty headers are in my future or I may go back in with the C4 for now. With that now on hold while I ponder it, will go ahead and start the fuel system mods for the EFI. I can manually shift the AOD and raise the rear wheels to get the first start on it if I have to.
    71gold likes this.
  6. 71gold
    went to Summit and picked up a few more odds and ends. got the mod done on my air breather.
    Thanks to"My Harold"...:thumbs2:
    BBMS18 likes this.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Test fitted the headers
    mavgrab302 and WiscoMav like this.
  8. Krazy Comet
    Dismal Swamp
    Are those headers supposed to fit Maverick? I don't see it happnin'. The #7 tube is going to be just about where the gas pedal currently sits(yes I mean inside the car) and no chance #8 is going to clear the steering box.
    This is amount of clearance between engine and steering sector.
  9. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    They are Hooker 6901 and from reading on here they are supposed to fit. Now im worried.
  10. Hotrock
    Munroe Falls, Ohio
    If those are Hooker 6901s and they appear to be; they should fit. Number seven and eight run beside and behind the steering box respectively and continue on past the rear of the engine block . That is assuming Hooker didn't screw up and the tube curves coming off the header flange are not as aggressive as they need to be . Hard to tell from your picture.
    I believe your headers will fit.
    6901s install quite easily from below. As I recall, you do have to get your car well off the floor both front and rear.
  11. Krazy Comet
    Dismal Swamp
    I hope my observation is wrong(As Archie Bunker would say... Optical conclusion?). The #7 pipe on Rick's header appears to be at a 90*, whereas Roger's is maybe 35* rearward. Rick's #8 pipe angles slightly rearward then toward front & 90* to rear. Until under car, neither pipe is past the mating of engine & transmission.
  12. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    As much as I value your experience and comments , I hope so too
  13. mojo
    Those headers look like the one's that came off my car. The only real way to find out is when they are installed-- that's where the "Rubber meets the Road". I found pic on my phone and the only tube that curves slightly different is the second tube front of engine. My headers were rusted out and fumes getting in car. Hopefully all will go well.
  14. 71gold
  15. Maverick_Ian90
    Maverick_Ian90 Member
    Northeast
    1975 Ford Maverick Grabber
    Received my engine gasket kit today... in a comically oversized box from Amazon.
    BBMS18 likes this.
