windshield seal stands
Discussion in 'General Maverick/Comet' started by 71gold, Dec 6, 2011.
  1. rthomas771
  2. MikeG747
    MikeG747 Member
    Arkansas
    Great Thread! (y)
  3. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Thanks for the pictures. No such parts on mine. Do I need them? Trim showed no tendency to fall off without them.
  4. rthomas771
    I think it holds the weight of the glass in position...taken the strain off the weatherstripping. :huh:
  5. Craig Selvey
    Yep....4 per car.
  6. Jsarnold
    '72 Sprint
    That makes sense. The glass did have a tendency to roll forward at the bottom. Guess I should have some on hand. If the trim ever has to come off I'd install them.
    Maybe they were discarded when someone changed the windshield.
  7. 71gold
    my thinking is...it holds the seal off the pinch weld, that keeps it from cutting the seal between the glass and the frame from the weight of the glass...:huh:
  8. blugene
    My 73 had two.
  9. mercgt73
    Mine too.
    Gene, our Comets are race version Mavericks, less weight for speed.
  10. blugene
    :D
    :drive:
    :rofl2:
  11. starsky74
    starsky74 Technician
    Hackberry Louisiana
    then what was the thinking behind that huge protrusion off the hood :D
  12. tody
    tody Member
    cologne, germany
    aerodynamics :p
  13. 71gold
    while we are here...
    the molding clips #... D0DZ-6203174-C
    to do front/back glass...box of 50
    these clips are...YELLOW ONLY...any other color will look like they will work, but won't...
    ...Frank...
    may need to move this thread to...tech.
  14. Dave B
    Just be careful, the aftermarket (auevco) one's are junk, they are too thin, and collapse when you try and install the trim.
    If you look in the service manual, they actually show different sized clips in the corners, they are green.
    (From left to right) Aueveco 10625, Clip from another supplier, NOS Ford clip too small, NOS Maverick/Pinto Ford clip, Original Ford clip
  15. 71gold
