1970 maverick want to put floor shifter in
Discussion in 'Transmissions' started by Catgirlie21, Sep 7, 2025.
  1. Catgirlie21
    Catgirlie21 New Member
    California
    1970 maverick
    1970 maverick that has a 70’s cougar transmission crossmember bar in it. It has a 1970’s c4 transmission out of a truck in it. Want to put a floor shifter in. The problem is that the piece from the transition that connects to the shift rod is going the wrong way. It’s going down and for a floor shifter it needs to go up. Is there any way to do that? Can I just turn it around?
  2. TeeEl
    TeeEl Senior Member
    Colorado
    You need a shift shaft for a floor shifter. If you can find one, swapping the shafts requires dropping the transmission pan and the valve body...
  3. Krazy Comet
    Dismal Swamp
    You need lever like this one on a '71 Floor shift transmission. Removed by dropping pan and removing nut on inside. May require removal of valve body.
