hi i am going to be putting a 351w into my 72 maverick grabber i was told it would bolt right in except the deck height is taller than the 302, i was wondering if there is any headers that would bolt right in without modification?
yep. go to the archives and put in 351w headers or 351w swap and do a search. off hand i know tubular has some. i have a set at home but i don't know what brand they are so there are some out there. put a good set of plugs in cause your not going to be changing them often. it's tight unless you do some mods to the shock towers.
any one know what axle spline the mav came with in 75, 302 9in. 3spd on column . 28/31 any would be great1
From the factory it came with an 8 inch and 28 splines. If it has a 9 inch under it someone put it under there.
yup 8 inch is in your 75 if its stock....28 spline...im also a member of the windsor club good luck with your install...have you shaved your shock towers? if not id recommend it , spark plugs WILL be a nightmare...far as headers ive herd of tubluar fitting pretty well however im not sure if any mods are needed to be done...far as i know there is no header that fits our windsor cars...i have hooker 6208s which are big tube 1 3/4...compared to tubluars 1 1/2 but if its a stock to mild 351w and your not racing or turning high rpms ... 1 1/2 will work fine...my car will be a mostly a drag car and i have alot of head work done so i felt it would help out....but good luck keep us posted if you have any questions email me or PM me have a nice day eddie
