5 lug conversion(1971 for the rear)
Discussion in 'Parts Interchange' started by falconscjman, Feb 25, 2012.
  1. falconscjman
    falconscjman Member
    phoenx, az
    74 2dr blue 250 6 cyl
    Ok, I just read a post on here that changing over to a 5 lug axle also means you have to have the 5 lug housing too. I picked up a pair of 5 lug axles awhile back & got new bearings on them & I was going to take out the 4 luggers & just install these 5 lugs & be done. But now I heard about the axle bearings are different sizes so I have to get the 5 lug axle housing too. Did I just answer my own question? :yup:
  2. jmgford
    jmgford Member
    Iowa
    The axle bearing O.D. on a 4-lug Maverick housing is smaller than the 5-lug housing. Someone told me that there was a bearing (possibly from an early Falcon) that might make the axle swap possible though.
  3. rayzorsharp
    I've read where some people have actually used the 4ug axles by getting them re-drilled. I personally would rather change out the entire rear end. You can usually pick up a complete assy for $100-$150. I've sold many of them.
