66 Galaxie 500 drivetrain to a 70 Maverick ?
Discussion in 'Parts Interchange' started by jordans mav, Jan 3, 2011.
  1. jordans mav
    jordans mav Member
    CA
    1970 maverick
    Will this work? will the parts interchange
  2. maverick75
    As long as its a small block/C4 It will swap. Although You will need maverick specific frame/motor mounts, crossmembers and exhaust.
  3. jordans mav
    jordans mav Member
    CA
    1970 maverick
    will the 9" fit
  4. maverick75
    There are only a few rear ends that will bolt in, i have never heard of the galaxie one being a bolt in. Also i cant find the measurements online to compare them to a maverick rear end. But you can always make it fit, by either having it narrowed/widened and having new perches welded on. Along with a pair of modified axles.
  5. mav1970
    If it's a 352/390/427 engine it won't fit
    A C6 won't fit into that little 70 Maverick transmission tunnel
    The 9 inch rear will be too wide
    Of course, anything will fit with a ton of work :burnout:
