67 bronco rear
Discussion in 'Parts Interchange' started by MaverickDan, Jan 1, 2007.
  1. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    will a 67 bronco rear fit under a maverick
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    to wide and big bolt pattern i believe
    perchs are to far apart...shocks might be different local
    so your answer NO unless you build a custom(y)
  3. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    YES, it will....
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    *The width is perfect for a Maverick.
    *The wheel bolt pattern is way big for a Maverick, however you can have it drilled and studded for the Maverick pattern. Either that, or you can use wheels that have the truck bolt pattern.
    *The spring pads are too close together and would need cut off and new Maverick style pads welded on. I believe the pads are also made for wider leaf springs, that is why I said you need Maverick style pads (Mustang pads would do fine)
    *When you have the axles drilled for the car bolt pattern, you would also have to find car pattern brake drums in the same dia/width as the drums currently on there.
    Those Bronco rears are a really good option for a narrow 9" if you have the patience to make all the little things work.
    Good luck
    Dave
  5. eddie1975
    Martinsburg, WV
    sold
    im wrong again sheesh doesnt happen that much :evilsmile
