68 Galaxie rearend?
Discussion in 'Parts Interchange' started by facelessnumber, Apr 9, 2009.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I'm sure it's probably a nine, but does anybody know anything else about the rearend in a '68 Galaxie? Is that a coil or leaf spring car, and where might I find the measurements on it?
    Thanks
  2. Ronald Hopkins
    Ronald Hopkins Member
    Morristown Tennessee
    1972 Comet GT
    That should be a 9" with coil springs.
  3. Craig Selvey
    Yes.....coil springs.
  4. facelessnumber
    Memphis, TN
    '71 Grabber
    Thanks. Probably way too wide too...
  5. tim keck
    sharps chapel,Tn
    Yep,too wide...
  6. Bryant
    grab the thirdmember out of it if you can. if your looking to put a 9" inch in it would be good to have several thirdmembers. you might get lucky and get one with a posi and a desireable gear ratio.
