70 Maverick Wiring diagram
Discussion in 'Parts Interchange' started by Bhuey55, Nov 26, 2008.
  1. Bhuey55
    Bhuey55 New Member
    Beaverton, Oregon
    Does anybody have a wiring diagram for 1970 Maverick? I'm trying to rebuild the car for my wife. Any help will be a big help. Thank you.
  2. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Here you go.
    Russ
  3. Bhuey55
    Bhuey55 New Member
    Beaverton, Oregon
    Thank you Russ.
    Carey
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Ditto the thanks, Russ. I was surprised to not find full wiring diagrams in the Ford shop manuals. Jim
  5. cmain125
    cmain125 Member
    arizona
    72 grabber
    i have the entire harness from a 72... will that work?
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    If your '70 has the ignition switch on the column and not the dash, it should be fine. ASSuming you're speaking of the dash harness (there are three main harnesses, front body, dash, and rear body) that is...
    Russ
  7. Jsarnold
    '72 Sprint
    I'm good. Just needed a wiring diagram to diagnose my faulty ignition switch. New one arriving tomorrow AM at Advance Auto. Thanks. Jim
