70 mustang disc brake on a 70 maverick drum
Discussion in 'Parts Interchange' started by greengt429, Jul 5, 2009.
  1. greengt429
    greengt429 Member
    Lordstown, OHIO
    70 Maverick Grabber, 69 mach1 351w 4spd, 71TorinoGT 429CJ 4spd sold last year, 90 LX 5.0 5 spd., 2014 Roush Mustang
    Has anyone tried to put disc brakes from a 70 mustang on a 70 maverick. Not sure if this is possible or not but I have everything from spindles to control arms. :hmmm:
  2. maverick maniac
    maverick maniac Banned
    owensboro ky
    yes they will work but you will need to use the mustang ball joints and tie rod ends i put them on my car
  3. greengt429
    greengt429 Member
    Lordstown, OHIO
    is it hard to plum up the valve from the mustang
  4. maverick maniac
    owensboro ky
    you can run without changing the valve you will never tell the diff. if you are wanting to put it on just re-do from the the lines
  5. greengt429
    greengt429 Member
    Lordstown, OHIO
    thanks for the info sounds like its going to be an easy swap
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Way more folks here run the stock drum/drum valve than those that actually swap the valves. No one has ever posted a problem. If you want to be thorough without swapping the valve, just put Crown Vic discs out back, then the front and rear brakes will be equal strength again and the stock valve will be the ticket! ;)
  7. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    I have those 70 mustang disc on my 63 ford fairlane of a 428 cobra jet and man they are much better than both my mavericks disc brakes !!!!! and I replace all the junk on the 76 mav disc brake system...with all new junk(replacement parts) but the big block disc are better in my on opinion... I should have gone after market on my 76 mav
      File size:
      383.2 KB
      28
  8. bmcdaniel
    bmcdaniel Senile Member
    I kept the original valve but have an adjustable for the rear line.
  9. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    crown vic disks?
