73 mustang throttle cable
Discussion in 'Parts Interchange' started by MaverickDan, Jan 29, 2007.
  1. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    will a 73 mustang throttle cable work with a 302 maverick
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Yes and no...
    It uses 2 bolts on the firewall instead of 1.
    The pedal attachment is different too.
    I have put one on a 72 Mav before.
    One of the cable holes lines up with the one hole on the firewall.
    So that was good enough I suppose...
    Then the clip to the pedal is pinned instead of crimped, Sooooo, I put the Stang pedal into the Maverick pedal piviot.
    The pivot that mounts to the inside firewall is totally different, so the arm had to swap to the Mav mount.
    Then the cable could be pinned to the arm and the arm could be mounted to the firewall...
    IIRC, the pedal 'pad' itself had to be swapped too.
    The Stang foot pedal pad was bigger and hit the tranny hump, so we put the smaller Mav foot pedal on the Stang arm.
    In the end, it worked fine... Still on the car, however to 'look' right, it could use another bolt hole drilled into the firewall. Then no one would ever guess.
    Dave
  3. stmanser
    Davenport, Iowa
    i bought a universal kit from checker auto parts... it fit great and works good as well
  4. Jamie Miles
    All of my Mavericks except my '69.5 have two bolts holding the cable to the firewall. The '69.5 had just a square hole, the cable had had clips the held it in place. I have since drilled a couple of holes and now run a regular cable on it also.
  5. ratio411
    ratio411 Member
    Pensacola
    Maybe I got it backwards...
    It's been a while.
    Maybe it was the Stang that had one hole and the firewall had 2.
    Sorry if that is the case.
    Maybe some Mavs are one and some two, cuz I could swear my 75 was one hole? :huh:
    Oh, well.
  6. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Yup, I have owned or seen both one hole throttle cables and two hole cables in Mavs. Also, my 70 Grabber has the square hole clip in one that Jamie described, so I guess that makes three different types of throttle cable attachments.
    -Corbin
  7. 71gold
    i have seen the 1 and 2 holes...:yup:
    ...frank...:bouncy:
