74 comet drum to brake
Discussion in 'Parts Interchange' started by cmt74, Dec 18, 2011.
  1. cmt74
    cmt74 New Member
    Toronto, ON, Canada
    74 comet 302
    I have a 74 comet 2 dr with all drum brakes. I would like to convert the front brakes to disc. what parts would i need? Should i just buy the conversion kit and what kit should i buy? Also have no brake booster and master cylinder needs replacing.
  2. Dave B
    Do a little searching (using the tech articles,and the search feature) , and a lot of reading and you should be able to find more info than you'd need. Also there are a few guys in Ontario that sell parts.
  3. cmt74
    cmt74 New Member
    Toronto, ON, Canada
    74 comet 302
    i have been reading some of the tech forums but all the conversion kits r for 1973 and under.
  4. Dave B
    They are pretty much all the same.
  5. maverick75
    75-80 Maverick/Granada/comet/monarch rotors, spindles, bearings, dust caps, hoses, calipers & pads, caliper bracket, non-power MC and the portioning valve.
    You may also have to buy the outer tie rods for a disc maverick, some require it and some don't.
    As for a kit one from www.discbrakeswap.com/ will run as much as piecing one together. It'll just save time to buy the kit.
    They don't have a kit listed for mav/comet but with just an email/call they will set you up with the right kit.
  6. Craig Selvey
    If you can find a Granada/Monarch or a disc brake Maverick in the junkyard, you need all the parts between the upper and lower ball joints.
  7. Dave B
    I'd be very surprised if you even found a Granada in Toronto.
  8. maverick75
    I've never even seen one here in southern California. I saw a monarch once!
  9. maveruss1
    maveruss1 '70 5.0 C-4
    Moreno Valley, Ca.
    1970 2dr.Maverick, 2005 Mustang
    I have 1972 magazine called small cars '72 . A guy Penn Lenson installed disc brakes from a 65-67 mustang. Comet and Fairlane will work also. The discs will bolt right onto the existing spindles if your Maverick has the early spindles and bearing size.
  10. Acornridgeman
    Wisconsin
  11. Craig Selvey
  12. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Tried starting a new thread but maybe shoulda just asked on this one. Did you guys actually use Swap2 or is that just the link you happened to grab? If Swap2, any special reason?
  13. Acornridgeman
    Wisconsin
    Definately use the swap kit #2 - as it is everything identical to the Granada parts. #2 has been the tried and true way to put disks on a Maverick for many years now. Why mess with success.
    :dance:
  14. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    AWESOME!!!! Thank you so much! :bowdown:
    When I called CSRP and they said Swap1 I got confused, as Swap2 looked like what I needed. Gonna email and order those suckers tonight!
  15. injectedmav
    injectedmav Member
    Georgia
    I wish that kit was around in the early 90's. That's a deal!
