74 to 73 rear bumper swap ?
Discussion in 'Parts Interchange' started by maverickdad, Aug 10, 2003.
  1. maverickdad
    maverickdad Member
    Martinsville Indiana
    1974 maverick
    I have a question about some parts. If I use a bumper, rear valance, bumper brackets and rear quater extions off of a 73 mav on my 74 will I also need to use the trunk lid? If so, would I be able to modify my extentions to work with the 73 mav bumper instead of changing out the trunk lid? Keep in mind that I also want to put on a grabber rear spoiler.
    Thanks,
    Steve
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Hey, MaverickDad.
    The trunk lids are the same for all years, except for the 2 vs 4 door differences.
    You will need:
    the quarter extensions-a bolt swap.
    the lower valence-this wil require holes drilled to attach.
    the rear bumper and brackets. The '73 rear bumper is
    the same as 70-72, but the bracket is unique to '73
    only. It makes the bumper sit back a little farther than
    70-72 cars. With that there was a body colored pad made
    of rubber material that goes under the quarter extensions
    and into the end of the bumper. It is a filler piece.
    The hardest part of this swap is cutting the holes through
    the lower section of the taillight panel and some required
    welding to attach the brackets in the trunk. These brackets
    can be purchased from Mustang suppliers, same bracket.
    Look for these to fit '69-'70 Mustangs, they are $12-15 each.
    Good luck.
  3. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
  4. maverickdad
    maverickdad Member
    1974 maverick
    another ? on 74 to 73 bumper swap
    Is there any problem on useing the 73 rear bumper parts you told me about from a 73 4-door mav onto a 74 2-door mav?
  5. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Hmmm...
    ...I doubt that there any differences other than the shape of the trunk and extensions on the four door. The mounting brackets etc. are probably the same.
    Seth
  6. maverickdad
    maverickdad Member
    1974 maverick
    bumper swap
    Thanks Seth and Corbin,
    You have been a great help.
