75-on Granada steering column
Discussion in 'Parts Interchange' started by DearbornMav73, Aug 20, 2003.
  1. DearbornMav73
    DearbornMav73 Member
    San Diego,Ca
    My Question is:Will a 1975-on Granada steerinf column fit a 1973 Mav two door?If so,what modification must be done in order for the column to fit.
    Thanks
  2. MavMark
    MavMark Mega Modifier
    Detroit Area, Michigan
    I have a related question...has anyone tried adding a tilt mechanism to a Maverick steering column...or have they swapped a different column with tilt into a Maverick? And...did Monarchs and Granadas come with tilt wheel as an option?(In case those columns would fit...:))
  3. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    There is an article on fordmaverick.com in the mechanical section with info on swapping an 86 taurus til steering column into a mav. If that helps at all...
    -Todd:)
  4. badmav70
    badmav70 Member
    pittsburgh, pa
    missing my 71 maverick i6 3 on the tree :(
    yes some granada/monarch and just about all lincolin versallies had tilt wheel. im trying to get out to where i know there is a tilt column in one, but just haven't had the money.. as far as it fitting in a mav off hand i don't know, but i have both a mav and a granada here that i can take some mesurements, i would think it would work, just out of curiosity what did the later maverick steering column look like (75-77)?
  5. badmav70
    badmav70 Member
    pittsburgh, pa
    did some checking today, the granada column bolts in a little differnt, so i would say that it won't bolt right in, but it could possably be made to work..
  6. MavMark
    The later columns are just about the same as the earlier ones as far as I can see...in fact, I bolted my '77 column right into my '72!
  7. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    Hey badmav70, what is the difference on the mounting places between the columns? Do they bolt in basically the same place, or what exactly is the difference between them? Are the sizes different? Is the bracket that bolts to the column to bolt it to the dash in the same place on both columns? Thanks.
    -Corbin
  8. badmav70
    badmav70 Member
    pittsburgh, pa
    i just got rid of my parts granada friday, im pretty sure that its differnt where the bracket bolts the colum to the car, im sure it could be made to work, but not sure how involved it would be.. i'll have to get in my granada and my mav and see if i can get some good pics, i tryed before, but they didn't turn out.. but there is visable differnce..
  9. Corbin Johnson
    That would be awesome! Thanks.
    -Corbin
  10. DearbornMav73
    San Diego,Ca
    so
    which other columns fit into a Mav(Mustang,Pinto,Falcon maybe??)
    And by "fit" i mean bolt in or minor mods required only
  11. RabidCustoms
    I installed a tilt from a 85 mustang into a project years back, it went very easy, minor mods were all it took,.but the wiring take time to sort.
