ok iam still in need of a insterment cluster plug the cluster is good but the plug is in bad shap all the pins r broke or missing i think all i need is the plug or the wireing with the plug can someone help?
Probably need to post up some pictures. I have never seen a plug go bad. If it is the plug...I can help you out.
yea it the plug most all the pins in the plug r bent or broke how can you help? can you just get me a cluster plug for a 1967 or a wiring harness to the plug if this dont help i can get some pictures thanks craig
I have a few plugs cut off, and I also have complete wiring harnesses I can part out. Pictures would be a big help.
Thanks for posting the pictures. I really don't SEE anything wrong with your plug. Mike is a lot closer to you...see if he can help you out. If not...get back with us.
