94+ mustang 8.8 rear disc
Discussion in 'Parts Interchange' started by mean_maverick, Jan 16, 2008.
  1. mean_maverick
    i wonder if the rear disc setup on a 94+ mustang could be used instead of the explorer or lincoln setup. i would imagine so, with it being an 8.8 and everything but i was wondering if anyone had an idea or had already tried this
  2. jb70grabber
    jb70grabber Member
    East windsor ct
    1970 maverick grabber 306 gt40 x heads and cam t-5 5 speed 8.8 rear 17 bullitt wheels also 76 low 22k 2dr undergoing restoration
    94 up mustang rear disk
    yes it can be done, in fact that is what is in my car. first the 8.8 and 7.5 both used the same brakes so if you already have a 79-93 stang rear get a 6 banger rear for a doner there usaully about 300 less than a gt rear second the only difference with these rears from a 79-93 rear is the axle lenth due to it having abs, but there is a company that makes conversion caliper brackets to us these set up on an older rears and they can be contacted at northracecars.com they offer this swap in a couple defferent ways i went with this set up because it is the best match for the 11 inch granada set up in front. good luck
  3. mean_maverick
    Thanks. I have a 94 GT parts car so i thought about putting the rear brakes to use :)
  4. Nitroracer
    Nitroracer Member
    Nottingham, Pa
    1968 Fairlane 500
    How close is the width on the SN95 rear axle?
  5. jb70grabber
    jb70grabber Member
    East windsor ct
    it all depends what you want to do, if you are still going to retain original offset wheels a fox style or 94+ rear will not let you they are both wider i don't rememember the exact amount but if your going the route of newer style wheels (cobra,bullits,etc) these rears fit very well. a sn95 rear shares the same housing as a fox rear so that measurement is the same but the axles in the sn95 are longer than fox in order to clear the abs trigger so this rear will over all be alittle wider but you can swap axles between the both but if your using the sn95 you'll need a new caliper mount to correct the math. hope this helps. jeff
