96 Explorer 8.8 rear into a 70 maverick
Discussion in 'Parts Interchange' started by John Lee, May 11, 2015.
  1. John Lee
    John Lee Member
    Suffolk Va
    1970 ford maverick
    I need help setting the pinion angle for this exchange. I have read other posts about the switch ...but not enough about pinion angle. Help please
  2. hectorsalinasx
    hectorsalinasx Member
    1969.5 Maverick
    Im on the middle of that too right now...and i was gonna get the angle off the 8 inch and just use the same angle
  3. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    That's probably the best bet.
  4. John Lee
    John Lee Member
    Suffolk Va
    1970 ford maverick
    I have done the same and still feel that with the extra HP....close to 400, that I would have to allow something for the rear rotating up on launch, then the consideration for the give in the leaf springs. Does this make any sense? Considering 5 degrees down. I am no mechanic by no means.
  5. John Lee
    John Lee Member
    Suffolk Va
    1970 ford maverick
  6. John Lee
    John Lee Member
    Suffolk Va
    1970 ford maverick
    Thanks for the help. I will continue down the same path as well
  7. Bryant
    coping the stock one is a good way to go. especially if you didnt have any vibrations at high speeds.
    the best way is to set the diff up in the car at ride height on its perches unwelded. then set the pinion angle 2 degrees down from the engine/transmission center line. the tack the perches in place and take apart to weld and straighten the housing.
    John Lee likes this.
  8. John Lee
    John Lee Member
    Suffolk Va
    1970 ford maverick
    Thanks for the info..sounds like a great alternative. Will make it harder, but I think with better results.
  9. jliverman
    jliverman Member
    I have a 70 maverick that I have been working on for some time. I have cut away the shock towers and replaced the front end with an RC 107 Mustang II front. It has a rack and pinion set up with coil overs. The set up for motor and trans has a 4 degree angle to the rear.
    When you said to set the diff at 2 degrees down from engine and transmission, does that mean in addition to the 4 degrees plus the 2?
  10. Bryant
    no it would be taken away. something like this
    so if your engine and trans are pointed up 4 degrees towards the front of the car, your diff should be 2 degrees up towards the front.
  11. jliverman
    jliverman Member
    I am not very good at telling you how it is set up. It would be 4 degrees toward the rear. I like the drawing, picture is worth a thousand words. Thanks...
