alignment issues
Discussion in 'Parts Interchange' started by greasemonkey82, Feb 12, 2004.
  1. greasemonkey82
    greasemonkey82 Member
    colorado springs
    73 maverick grabber
    o.k. my maverick has a really bad front end. practically every bushing is bad. my front left tire wears thin on the inside. two months it will ruin a new tire. i was wondering if there is a whole front end from another car that i can use. maybe one that will be alot better than the origonal.
    :smash:Thanks.:smash:
  2. bmcdaniel
    bmcdaniel Senile Member
    You can buy performance suspension kits made for the Maverick. Check the archives on this board. Sounds like your tire wear is caused by too much negative camber, it's easy to adjust or have adjusted.
  3. Marlboroman76_3
    Marlboroman76_3 New Member
    OKC
    72 2dr mav
    you could try gettin a stang master suspension kit it might be a little cheaper. I have got that same problem, gotta get a new front suspension
