are there any fiberglass fenders for a maverick?
Discussion in 'Parts Interchange' started by MaddMav, Mar 29, 2004.
  1. MaddMav
    MaddMav Member
    If so, are they available for a 73? If not, can I interchange the fiberglass fenders from another year? Also, what about that front bumper on the 73? Looking to knock the weight of a 73 down...if I end up getting a 73.
    If it makes any difference there will be a M II front end on it as well....try to lose the front end weight because of the 460 going into it. It has aluminum heads, and an aluminum tunnel ram. No AC, no PS, battery WILL be located to the trunk. H2O pump will also be aluminum if not electric.
    I figure with the aluminum headed/intake w/o the acessories will put the weight down close to an all iron 302 with the accessories--with the battery in the front. With the fiberglass front end and everything listed I am very confident the weight will be less. Thank you much.
    Jeff Given
  2. bmcdaniel
    bmcdaniel Senile Member
  3. MaddMav
    MaddMav Member
    Will go onto a 73?
    how about fixing that crack??
    And the 73? I plan on getting rid of the 73 bumper and putting on my bro's F250 :)
    Jeff Given
  4. bmcdaniel
    The crack has been glassed in on the bottom. The gel coat needs filled in on the top. The only difference between Mav fenders of any year is the notch for the bumper. I had these on my '70 before I redid the whole body.
  5. igo1090
    igo1090 Member
    catonsville, md
    hope you're not disappointed on the weight issue. a 302 used to weigh about 450-500 lbs. if i remember right, a steel 460 is close to 750. aluminum heads and intake might shave 150 lbs.
  6. Mercurycruizers
    Venetia, PA
    Have you tried the Maverick Connection? There phone number is (304) 372-7825 M-F 6pm - 10pm ET Sat & Sun 10am - 10pm ET or you can email at: maverickconnection@email.com The have fiberglass fenders, hoods, bumpers, trunk lids, stone guards Front & rear valance panels, & even a full Maverick tilt front end (70-73) $449.00. They also have fiberglass front spoilers. I just ordered the front spoiler for my 73 Comet.
  7. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    Maverick Connection does have all the stuff you need, if you don't mind paying higher prices. You can get all the stuff that is available from other places at more reasonable prices. But hey, it's your money!! :D
