Automatic to Manual steering wheel/motor/trans swap
Discussion in 'Parts Interchange' started by Lzoesch, Jun 24, 2011.
  1. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    I am going to be starting the process of switching out a motor, 3 speed manual and a steering column. My question is how and is there a way to pull the entire column assembly including the clutch peddles and everything needed in one easy pull. Also do I need to pull the manual steering box? I don't have any experience doing so, so I'm a little nervous.
    Is there a diagram on how to do the swap?
    Motor/trans ive done before and not worried -- but on the transmission hump in the interior side where do I cut the square out to install the floor shift kit? Is there a pretty easy way to figure this out, or is there a standard location?
