i wanna install a holley electric pump with a return line ,i have looke dunder the rear of the maverick and cant really see a good safe place to install ,i plan to also hang a canister style fuel filter as well ,any ideas? i still have stock fuel tank
first: be sure to install an oil pressure sensitive 'safety switch' on ignition with the electric fuel pump . dunder the Maverick you can follow the OEM line front to rear. The Fuel Pump unless in tank (preferably), should be close to bottom of tank. I mounted an inline at front of tank behind axle and added large filter before pump. Return line from boost ref'd bypass regulator (SC'd sealed/blown carb) simply dumps into fuel filler in trunk. 3/8 bendable brake line makes it manageable. have fun . . .
