Blue distributor cap
Discussion in 'Parts Interchange' started by welch1jim, Sep 28, 2008.
  1. welch1jim
    welch1jim Maverick-iac
    Massachusetts
    1976 Maverick 302
    My 1976 Maverick (302 V8) still has the original blue distributor cap and rotor. While there is no burning need to change it now, let's recognize that these things eventually fail, plastic deteriorates, contacts wear, etc. I did some online searches and did not immediately see replacement units in the true blue color. My first instinct was to buy a Motorcraft or other high-quality replacement part. Are there sources for high-quality replacements in the blue color? What retail sources are recommended? Other ideas? Thanks.
  2. Bob Wiken
    Fayetteville, Arkansas
    HMM?? Paint a new one?
  3. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I know some of the more reputable aftermarket manufacturers like MSD make blue ones that you can order and I think they still make OEM blue ones too.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    When I worked in an auto parts store years ago, Standard Ignition products had 2 grades of products. Looks for their high end Blue Streak product it will have a X at the end of the part nimber. If I remember correctly they were blue.
  5. Dave B
    Is it blue and says Motorcraft on it?
  6. welch1jim
    Massachusetts
    1976 Maverick 302
    Thanks. My Ford parts man tells me the Motorcraft units that you can buy new are gray. Likewise, I checked the website for Standard Motor Products and found gray color distributor caps. I did not find a specific part number for the Blue Steak product line...gave same part number as regular line. I will research the MSD option...Thanks to all.
  7. maverick1970
    Missouri
    On Standard Ignition it is the same base part number just add an X to the end.
  8. welch1jim
    Massachusetts
    1976 Maverick 302
    Here is an update. The pointers you all have given have made this possible. I have learned that my problem/challenge is specific to 1975-1976 model years.
    Blue Streak from Standard Motor Products makes a high-end blue distributor cap to fit 1970-1974 Ford V8 (and older, but this is a Maverick forum). This is the points-and-condensor-style ignition. The applications guides call for a different part number for 1975-1976, which is electronic ignition. Blue Streak no longer makes the part for the '75-'76 application. However, the folks at Standard Motor Products suggested that the older-style part number may work. Does anyone know what the actual difference is between the two caps? My next step is to buy one and make a visual comparison.
    Other notes: New distributor caps sold by MSD and other suppliers for this appilcation are either gray or black. None are blue in color. I found an old NAPA cap on eBay, but it was NAPA's lower line and is no longer available. There may be some NOS parts out there somewhere, but it will take some time to find them. Not as easy as going to your nearest parts store and asking for the readily-available part...
  9. Dave B
  10. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    The cap I got for my HO motor is turd brown (matches what the car used to be) and the cap adapter is black.:16suspect
  11. Jamie Miles
    I'd just spray bomb one blue.
  12. Shinysideup
    Shinysideup Chillin the most
    town
    car
    I found mine in a JY,like new. Actually matches the ford blue(pic is off from flash). So it was an old Napa part?
  13. welch1jim
    Massachusetts
    1976 Maverick 302
    From your picture, looks like you have a distributor and cap from a 1977 or newer vehicle. That is a different part than mine, which fits only 1975-1976 with the socket-style connectors. Cannot determine from your picture who manufactured your distributor cap. It could actually be the OEM Ford/Motorcraft part. If you pop it off and look inside, it might have some identifying markings.
  14. maverick75
    No trying to hijack the thread but is anyone make clear distributor caps?
  15. welch1jim
    Massachusetts
    1976 Maverick 302
    Try searching for "Clear Dist Cap?" There is another thread on that. Thanks.
