Bottom Door Gaskets
Discussion in 'Technical' started by Slider28, Jun 9, 2019.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    I just got my set of bottom door gaskets from A.K. I thought there would be a 3m type of peel and stick, but there isn't... Do I need to get some adhesive glue to put them on?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    3M 8008 Adhesive
  3. Slider28
    Slider28 Member
    San Antonio, Texas
    Got it! Thanks!
  4. Slider28
    Slider28 Member
    San Antonio, Texas
    I am getting close to installing my gasket.. There is a TRACK at the bottom of the door. I have Not got ready for the gasket. But is this this track for the gasket?? Or Do I need to show some pictures?
  5. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    please explain bottom door gaskets. I don't think my car has any. Thank You.
  6. Craig Selvey
    Yes, the gasket glues in the track.
  7. Acornridgeman
    Wisconsin
    Here is a tip. Pull your battery cable because you will want to leave the doors open overnight while the adhesive cures. Use masking tape to hold it in position. Don't stretch out the gasket while installing. And the metal tab goes to the front but don't use sealer at that spot. It needs to move a little when the door closes.
    Craig Selvey, mojo and Hotrock like this.
  8. Slider28
    Slider28 Member
    San Antonio, Texas
  9. Ronald Hopkins
    1972 Comet GT
    Ok sorry I have those. I installed them. I thought maybe it was a gasket that went on the door bottom that I had missed.
