building a 8 inch
Discussion in 'Parts Interchange' started by mjm0395, Mar 19, 2010.
  1. mjm0395
    mjm0395 Member
    Everett wa
    1972 Yellow Comet, 1966 Ranchero
    I have a stock 1972 8 inch rear end. What gears come stock in it, and what would you prefer in it? 355, 380? Which is more realistic for street performance?
  2. maverick75
    Check your door tag for the "axle code"..."3" is 2.79 gears and "6" is 3.00 gears.
    Set it up for 3.55 and you'll be happy :Handshake
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    best replacement depends heavily on the transmission gear ratios... t-5 vs c-4 vs AOD etc....
  4. mjm0395
    mjm0395 Member
    Everett wa
    stock aod out of a lincoln
  5. maverick75
    ahhh then take the advice of Paul...our transmission guru from washington :tiphat:
  6. sierra grabber
    northern nevada
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Depends on how you drive it most of the time. If it were mine and it was mostly used around town and some minimal highway use it would be 3.80's or 4.10's. If I used it to commute on the highway regularly it would be 3.55's. Mine is getting 3.80's when I get to taht point since it's more of a toy than transportation and low gears are FUN!
