c4 auto shifter
Discussion in 'Parts Interchange' started by seth, Jul 24, 2009.
  1. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    will a auto c4 floor shifter work with a bench seat?
  2. Earl Branham
    Lugoff, SC
    Yep, ran one for years. Here is a tip...if you get a '67 or so Mustang shifter, it is a bit smaller, and works the same. Makes a better look, and more room for the bench. But, a stock or aftermarket will work too.
  3. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    im guessing u didnt find anything for that plate
  4. Earl Branham
    Lugoff, SC
    Seth; just sent you a pm. I found the inspection cover, and I am cleaning it up a bit and sending it on Monday. Should be there in a few days.
  5. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Hey Earl, I was thinking of going ahead and converting mine from the column to the floor, before I get my bucket seats re-done someday. Is using the factory hole in the floor to mount a factory automatic Maverick/Comet floor shifter possible and still have full function of the gears? I thought the bench was to close to the shifter? or am I mistaken.
    Thanks
  6. Earl Branham
    Lugoff, SC
    I put my Mustang shifter in the stock position, and had no problems. Be aware that the floor shifter had a hump that you can use to position the shifter up and to the left side of the tunnel. If you use the shifter on the floor, you may have to enlarge or reposition the hole. Just make sure to get a floor shift manual selector arm for your trans. They are different. Good luck.
  7. Maverick73
    Lakeland, FL
    Does anyone have pictures of a factory automatic floor shifter installed with a bench seat?
  8. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    hay does anyone have a floor shifter that they dont need id be willing to take it of of your hands
  9. Maverick73
    Lakeland, FL
    Still in search of a picture with a factory automatic floor shifter installed with a bench seat.
  10. seth
    seth Member
    Edgewood M.D
    1969.5 maverick
    you to!!!!
  11. beeje40
    beeje40 Member
    hewitt, texas
    71maverick, 80 mustang, 84 mustang, 70camaro, 67camaro, 7o nova, 68 chevelle
    I kno that the '69 torino haad a cut out in the bench for floor shifters and ive always ran buckets in my mavericks so i m not much help but think there isnt much room for a shifter there. atleast not to use all gears maybe just drive?
