Putting a 4 speed in 72 mav with c4 Looking for clutch assy-Z bar-cross member parts. would a 80 Granada be interchangeable? 65 comet? All the pedal assy here don't have Z bar. Hyd or cable don't sound as positive for hard shifting?? Educate me. Myway
mabe this may help I just did the change over it was so easy I use a set of maverick clutch and break pedals that I brought off of this site for 175 I used the pivot ball out of a 67 mustang on the frame rail just had to notch 1 hole a little bit bolted right in I used the zbar also I had to add 1 1/2 inch to clear the steering coupler real easy also and I think I shorten the rod from pedal to zbar 2 1/2 inch the pivot ball to the block also from the mustang all these parts easy to find I was going to try hyd or cable but I already had these parts for my mustang I was doing tell I found my maverick I used a top loader 4speed and I love it also all the parts where for a 289 0r 302 I hope this help you maverick parts are so hard to find
