cooling fan
Discussion in 'Parts Interchange' started by comet72, Jun 2, 2010.
  1. comet72
    comet72 Member
    72 comet 2 door v/8
    hi all i need some help i have been looking and no about the 6 blade tigerfan for the 250 6 cyl with air i have 3 of those but i just took apart a 76 comet 250 6 cylinder with air car and it has a 7 YES 7 blade factory fan with aluminum fins 45,000 mile original car # are cf-dide 8600-ba
    7 blade can any one tell me how rear this is? as i have never seen a 7 blade on a 250 6 cylinder factory car, like i said i have 3 6 blade tigers what do i have here? thats in advance
    comet 72
  2. maverick75
  3. comet72
    comet72 Member
    72 comet 2 door v/8
    fan
    thanks but i have re checked it and that is the # that is on every blade hope to get some help thanks in advance
  4. dtb147
    dtb147 Member
    Arbutus, MD
  5. comet72
    comet72 Member
    72 comet 2 door v/8
    Thanks for the help so far as yes those are the numbers on the blades
  6. dtb147
    dtb147 Member
    Arbutus, MD
  7. comet72
    comet72 Member
    72 comet 2 door v/8
    that is the fan i have in my hand that is it to the t wonder what is is worth?
  8. maverick75
    apparently you didn't check it good enough because it should be
    CF-D1DE 8600-BA
    Australian 6cyl stuff is expensive....now the real question is do you have an Australian 250 head? :)
    is the intake and exhaust on the same side? if so then its just a regular American piece. If they're on the opposite sides then its an aussie piece.
  9. comet72
    comet72 Member
    72 comet 2 door v/8
    motor is still in car as i speak
  10. rthomas771
    Ford didn't use the letters i or o in the part numbers...They used numbers 1 and 0
  11. comet72
    comet72 Member
    72 comet 2 door v/8
    fan
    yes my mistake sorry......
  12. PaulS
    hey, it's a common error that folks usually make once. No big deal.
    The Australian head has a removeable intake manifold - check to see if yours is a bolt on or cast in head/intake manifold. The head is worth a lot of money!
