Disc Brake Swap Front
Discussion in 'Parts Interchange' started by mrskydog, Feb 25, 2009.
  1. mrskydog
    Muskegon MI
    On my 1973 Maverick, If I swap front Brakes to a disc system, and I have Magnum 500 14" Rims on this car, will there be any clearing problems with caliper system? or do I have to go to 15" rims?
    Thanks ,Kirk
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    My 14" mag 500 fit OK. HOWEVER! i did have to grind down the casting lines on the calipers just a little. the main body of the caliper clears but that casting line was rubbing. just used the sander wheel on the dremel to clear it and i dont believe i cut into the metal enough to make them lose their strength. been running them that way for over 9 years with no problems...
  3. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Exactly what I had to do. Works great, about 30min work.
