disc brake swap
Discussion in 'Parts Interchange' started by pegleg1858, Apr 19, 2012.
  1. pegleg1858
    pegleg1858 Member
    kentucky
    69 1/2 maverick
    Swapped in disc brake on a 69 1/2 maverick and added the 8 inch 5 bolt rear end. Also installed a 74 non power, disc brake master cylinder. Do I need to install a proportioning valve from a disk brake maverick also?
  2. 4doorlvr
    4doorlvr Member
    North Tacoma, WA.
    So are you running disk all around now, or just the disk up front and drum in the rear? also have you swapped any of the original Hard lines?
