Door hinge pin/bushing availability/interchange
Discussion in 'Parts Interchange' started by masondr19, Jun 1, 2004.
  1. masondr19
    masondr19 Member
    76 Mav 4 door: Can't find these locally. Nobody, including Napa and Dealers lists anymore. Other Ford models interchange? Best place to get these and other parts?
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I just put a NAPA door hinge pin in my 71 Grabber prior to installing the doors ... Not sure if 4-doors are different ... Grabbed it off the rack containing "HELP" type parts for all different cars ...
  3. Jean Doll
    Palmerton, PA
    We get our door pins from our local Car Quest store. I think AutoKrafters carries them too. In a pinch, the door pins for a 1985 to the 1990's Chysler will work too. Chylser has long and short pins. The short pins are too short, but the long pins fit just fine. You would need to hacksaw off the ends though.
  4. masondr19
    masondr19 Member
    Thanks for info. Found "ford" pins on the Help section of local Advance parts store,
