At least they won't stick and there's no chance of being locked out! That's two good reasons to use 'em right off the bat!
Just take you a rope, tie around the door handle and then tie it around the head rest. Good to go! Or, you could just cut the body down in the middle so the door will close. Call it the Maverick SS, for "Super Short". I'd like to see a photo shop of that, a 4 door with a 2 door back end grafted on at the center pillar. Or maybe a 4 door with 2 door back end grafted on at the rear door, bolt the 2 door rear doors on the center pillar, make a Limo.
door actually when i was younger i had a old scout 4x4 and i used the rope trick on it . then got a little money and put a fence latch on it . i talked the wife into not getting a bigger car.so im keeping the comet
one time i left the door open to my town car and backed into it with the monte and bent it back. i had to roll the window down a little bit and wrap duct tape arount the window frame and door pillar. i junked that POS a month later. if i knew i was getting a maverick i woulda kept it for the 5.0 but at the time i had a yard full of g-bodys, what was i going to do with a 302?
