Drum Brakes Issue
Discussion in 'Technical' started by 70Maverick70, Mar 21, 2016.
  1. 70Maverick70
    70Maverick70 The faster the better!!
    Manitoba
    That's defiantly making my theory more accurate then. When i measured mine it came out to 5 13/16".
  2. airford1
    airford1 Member
    San Dimas, Ca
    You should be using 1/3 to 1/2 the stroke of the master.
  3. 70Maverick70
    Manitoba
    Hey guys! sorry for the late response. But the issue has been solved. The cause of the low pedal and no brakes was due to the wrong length cylinder rod. I found and removed the original rod that was in the car and swapped it with the new M/C. The difference between the lengths was just under 1 inch, which made a gigantic difference in travel. Everything now works great!
    Thanks for the help.(y)
    NCFatBoy likes this.
  4. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Very good you found the problem ..
