Explorer Power Steering Cooler
Discussion in 'Other Automotive Tech & Talk' started by mav1970, Aug 16, 2012.
  1. mav1970
    My power steering oil cooler leaks in my 01 Explorer and was wondering if I could simply bypass it and not run one. I think the Ploder has less than 1,000 miles on it since last year so it don't get used much.
    Any thoughts?
  2. simple man
    simple man Member
    Bunnell,Florida
    I would replace it with something that will cool the fluid! A lot of the parts, including the reservoir, are plastic and won't stand the heat. You can get a replacement pretty easily from a junkyard, or a small trans cooler from the auto parts store would work fine. :)
  3. Dave B
    The 96 Explorer I had, they had cut the factory one out, and just put in a small aftermarket one.
  4. injectedmav
    injectedmav Member
    Georgia
    I would probably replace it with a small aftermarket cooler, those systems generate a lot of heat. The OEM one is probably obsolete anyway.
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    Moved to other auto.
    Also, I wouldn't eliminate a cooler personally.
