fox body parts on a 70 mav?
Discussion in 'Parts Interchange' started by my70mav, Apr 9, 2009.
  1. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I should be picking up a 70 2 door mav with a 6 and an auto this week with the intention of using as much of the parts i have on my 91 mustang. I may have missed it but i haven't seen much about swapping parts from this style mustang.i plan to keep the efi and i have a number of performance parts and am hoping someone can tell me what i can and cant use.i have no problem doin a little cut and weld here and there,here is a list:
    91 gt 5 speed, mac fenderwell cai,
    forged long rod 306,flowmaster cat back,
    shaved gt40's,msd coil, msd wires, msd 6al,
    e-cam,kevlar clutch,o/r h-pipe,4.10 gears,
    255 lph pump,3g alt,underdrive pullies,c&l 76mm maf,
    tmoss upper & lower,mark vIII fan,bbk shorties,65mm tb
    ,rear summit tubular upper and lower control arms,aluminium rad,
    a/c and smog pump delete
  2. mean_maverick
    as for the engine and trans, you can drop them in.... that's about it from a fox
  3. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    The drive shaft fits right in too.Just have to remove the 4 bolt flange.
    The best thing to do is to sell off all the FOX suspention parts and assorted stuff and use the cash for the right Mav parts.
  4. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    any recomendations on "the right parts"?
  5. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    5 lug disk breaks off of a maverick or Granada. Youll need the spindles the caliper bracket, the rotors if there good and the caliper for a core if any thing.
  6. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    can i just buy the spindles and pickup new calipers and rotors? is that lug pattern the same as the later model ford 5 lug?
  7. Bryant
    you can use all of this stuff.
    mac fenderwell cai, will have to do some modifications and cuting.
    forged long rod 306, you will have to change the oil pan and oil pick up to a front sump type.
    flowmaster cat back, you can use the mufflers but will reqire new pipes.
    tmoss upper & lower,65mm tb
  8. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    i figured i would need the oil pan and pickup,i may just switch to a carb setup to simplify things.
    i plan on using the engine,trans and rear end.
  9. Bryant
    you can go to a carb really easly. the trickest part is the distrubor. you will want to get a dist. for a 85 5.0 mustang with a manual transmission. it has the correct gear for the roller cam. it will work with you msd box. just follow msd's instructions. for the fuel system you have two options. change the front cover to a cover with a fuel pump boss or use a eletric fuel pump.
  10. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    I'am leaning towards electric fuel pump and an msd distributor
