Front coil springs
Discussion in 'Parts Interchange' started by madmavero, Aug 10, 2003.
  1. madmavero
    madmavero New Member
    1973 Maverick
    Hello, I have a 73 maverick with a 250. One of the front coil springs is bent and causes the shock absorber to wear out. Also, the car origianlly had AC but that has been removed and I'd like the car to ride a bit lower anyway, so what is a good choice for replacement springs (I will do both) How can I get the specs to compare different springs, either other ford springs or otherwise?
  2. Mavaholic
    you can check this sight out. They sell springs and can probably help you out with spring rates.
    http://www.springsnthings.com/
    Just curious, how do you bend a coil spring in a manor that causes the shock to wear?
