Glass...
Discussion in 'Parts Interchange' started by Crazy Larry, Mar 14, 2016.
  1. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Is the door glass interchangeable between Mavericks and Comets? I know it's the same physical size, but are the mounting holes the same size and in the same place?
  2. 71gold
    I know Mavs. have two different spaced holes in their door glass...:yup:
    Craig Selvey likes this.
  3. rthomas771
    Also come tinted and non-tinted. Some have the regulator riveted to the door instead of bolts making it hard to remove the glass without drilling out the rivets.
  4. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Different from the Comet? Or different between model years?
    Paul Masson likes this.
  5. 71gold
    this I don't know. I had an unknown year NOS pass. door glass that we put in Jeff's 74. it had a different hole spacing than another NOS driver door glass.
  6. Craig Selvey
    Different holes by year....not by model. Not sure where the year break is.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Thanks, guys.
  8. rthomas771
    Here are a few changes I seen. 70-74 have the 24" hole spacing...76-77 have 20".
    The regulator support on the 70-74 is close to the rear corner of the cutout...76-77 the support in more in the middle of the cutout.
    76-77 have rivets holding the regulator to the door shell...70-74 uses bolts.
    76-77 have a smooth finish metal on the interior...70-74 has texture grain metal.
    Don't know nothing about the '75
  9. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Thanks. That's some good information.
