global west upper control arms
Discussion in 'Technical' started by 73curtis, Jul 1, 2015.
  1. 73curtis
    73curtis Member
    ohio
    does anyone use the plus 3 upper control arms for the street, and are roller perches worth it. Does anyone run both
  2. 73curtis
    73curtis Member
    ohio
    global wests tech department said new lower holes must be drilled, I asked if it would change the ride height he said no, how can that be if your lowering the arm, he didn't explain he just guaranteed the ride height would be the same?
  3. bmcdaniel
    bmcdaniel Senile Member
    I've been running roller perches for a few years now, definitely made the front end act smoother.
  4. 73curtis
    73curtis Member
    ohio
    what control arms do you have?
  5. bmcdaniel
    Stock.
  6. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    There's a good chance that Global West has engineered the arms so the change in mounting location doesn't change the height. That could easily be done with placing the mounts for the spring perch farther off the arm. Even if you do it to stock arms my understanding is it doesn't change the height much.
    injectedmav likes this.
  7. injectedmav
    injectedmav Member
    Georgia
    Roller perches are smoother operating, I use street or track upper arms. The perch mount appears a little bit higher on them than the stock arms in relation to the pivot. That would likely offset any drop in suspension height from lowering the UCA mount. I did notice that when I installed them it actually raised the front end up almost 1/2" from where I had it. Annoying mainly because I liked the stance. I'm going to lower it as soon as I can. I actually had to redrill the holes slightly higher than I had them since I originally had the most aggressive Arning drop at 2" below stock. The instructions for the tubular arms dropped the pivot holes approximately 1 1/2"
  8. StaffAmerica74
    StaffAmerica74 Member
    Easton, Pa
    Roller perches are great... front feels nice and smooth with them
  9. 73curtis
    73curtis Member
    ohio
    changing mine soon.
